TwinTurbo.NET: Nissan 300ZX forum - I would question the accuracy of the fuel sensor
Subject I would question the accuracy of the fuel sensor
Posted by Zvil (FL) on January 19, 2017 at 10:23 AM
  This message has been viewed 345 times.
In Reply To Oh. Forgot to mention. posted by kickerzx on January 19, 2017 at 07:39 AM
Message or maybe this is not a volume/pressure issue but instead a flow issue and the amount of volume and pressure required to overcome the pressure drop before the regulator doesn't matter is not achieveable... or maybe the filter is clogged.... or maybe there's not enough current feeding the fuel pumps?.... perhaps the stock rails restrict in series but if they are fed in parallel the pressure drop would not occur? My afr's are safe for both banks and are within .2 of each other at full tilt. I'll take my chances for now... I will look into it though thankyou.
____________________________________________________
"The dreaded 2nd windshiled wiper swipe when you turn it off its almost like tis showing you that it's boss, and it doesn't have to stop when you tell it to :("-College Boy
(discussion on ptu relocation)
"No good reason to put it there anyway. -Bernie (NoVA)
False -vorpalZ
False. -Bernie (NoVA)
You're correct, there are 3 good reasons -vorpalZ
Wow, right again, just remembered another, make that 4 -vorpalZ"
XD
