TwinTurbo.NET: Nissan 300ZX forum - My z used to be scary when it would break loose until I put
Subject My z used to be scary when it would break loose until I put
Posted by hunterg on December 13, 2016 at 3:55 PM
  This message has been viewed 663 times.
In Reply To Re: They're honestly not that bad posted by jgbatlantaZ on December 13, 2016 at 02:50 PM
Message A proper LSD to replace the clapped out viscous unit. As I would get into boost it would break one tire free before the other resulting in a massive lunge to which ever side broke loose first. Admittedly I almost wrecked it on the highway one cold wet night in GA when I barely dipped into boost in 5th gear at about 70mph(NA subframe)- the car broke loose exactly as you describe with very little warning. I thought it was an improper alignment at first but had a couple different shops easily get the alignment into proper spec. After installing the Nismo clutch type unit I can hold it straight very easily when the tires spin no matter the speed. If you need a good diff builder local to Atlanta shoot me an email. He can replace the viscous unit and carrier bearings pretty cheaply and leave the pinion bearing alone(saves A LOT of $) as long as your pinion bearing isn't shot.
