TwinTurbo.NET: Nissan 300ZX forum - fuel check valve discontinued?
Subject fuel check valve discontinued?
Posted by surfer31337 on August 16, 2016 at 12:44 PM
  This message has been viewed 978 times.
Message when i do a fuel pressure test, the pressure drops immediately unless i pinch the return line, then it holds for awhile. i was advised by another member the faulty part is this fuel check valve outside the tank, underneath the car on the drivers side. i went to order a replacement and they were discontinued and no longer available.
what should i do? these are the two different part numbers i tried to order. is there an aftermarket replacement? what's the purpose for this valve? can it be bypassed? thank you
17370-30P00
17370-30R00
