TwinTurbo.NET: Nissan 300ZX forum - Re: Engine re-assembly of stock short block. Tips and tricks??
Subject Re: Engine re-assembly of stock short block. Tips and tricks??
Posted by dfenton2 on July 30, 2016 at 1:14 PM
  This message has been viewed 390 times.
In Reply To Engine re-assembly of stock short block. Tips and tricks?? posted by LivinTheDream on July 30, 2016 at 10:52 AM
Message The engine rotating assembly will wear slightly even if everything is still good. You will more than likely be alright with factory spec bearings but it never hurts to double check just to be sure. It would be a terrible feeling if your bearings were a little loose and pouring oil causing lower than desired oil pressure.
