TwinTurbo.NET: Nissan 300ZX forum - Re: Need info on TPMS (tire pressure monitoring system)
Subject Re: Need info on TPMS (tire pressure monitoring system)
Posted by freak152000 on June 08, 2016 at 9:00 PM
  This message has been viewed 664 times.
In Reply To Need info on TPMS (tire pressure monitoring system) posted by ZTicket(Dallas) on June 08, 2016 at 05:57 AM
Message [ http://racegrade.com/TPMS.html ]
Can be used with 4 receivers that will then detect which sensor is where.
2 antennas report back to the main unit. The sensors measure pressure and air temp can also be had with sensor that have IR temp sensor to measure carcass temp.
The down side is that you need something to read/display the data output from the unit. Normally this is done with loggers or a dash that has user defined CAN inputs.
