TwinTurbo.NET: Nissan 300ZX forum - best options for replacing front lower control arm bushing?
Subject best options for replacing front lower control arm bushing?
Posted by ZEngineer on June 04, 2016 at 12:01 AM
  This message has been viewed 993 times.
Message I replaced my inner and outer tie rods to fix a vagueness in my steering, but that didn't solve the problem completely. However, when the tie rod and tension rod were disconnected, I noticed lateral play in the lower control arm.
Is the best option to replace the whole control arm with a new one, or to put in a new bushing? Search says that the bushing replacement is a real PITA.
Also, how frequently does the ball joint go bad on the front lower control arm?
Thanks
____________________________________________________________
Im n0t Sarcastic (Kenny): not to over
do it, but you're certainly the source
of high-class Z
mods
ZEngineer24: what do you mean by that?
Im n0t Sarcastic:
I just mean, your Z is one I really admire
"The Z is the cause and
the solution to all my problems" -- Me
"If your car was my car, I'd think
it's broken"
src="http://www.photodump.org/stored17/_DSC2122_originalSmall.j
pg">
