TwinTurbo.NET: Nissan 300ZX forum - In which way is the SPL an upgrade? (Legitimate question) (n/m)
ZEngineer
on May 18, 2016 at 5:01 PM
Upgrade to SPL and send your old units in as cores (n/m)
posted by Bernie (NoVA)
on May 18, 2016 at 04:34 PM
How to avoid destroying Tension Rod ends?
ZEngineer
13:21:34 05/18/16
You are on the right track
ttsmokin
14:20:51 05/18/16
Thank you. This is helpful. But if I'm installing them
ZEngineer
17:04:38 05/18/16
I install them twisted close to the limit. That seems
not4resaleZ
17:20:50 05/18/16
if car is on stands, couldn't you use the jack to raise the
20:16:21 05/18/16
You could set the car on blocks under the wheels,
not4resaleZ
09:30:09 05/19/16
seems a lot more unsafe to actually have the weight of the
13:11:40 05/19/16
If you lift the wheels into a similar position, the weight
not4resaleZ
16:28:36 05/19/16
not if you don't raise the car off the stands
18:11:58 05/19/16
Stands + nixit blocks. (n/m)
BoneZ (MD)
13:38:07 05/21/16
Do you require a custom caster setting up front?
Polish
14:21:02 05/18/16
I haven't had issues with these tension rods
ZEngineer
17:02:55 05/18/16
16:34:25 05/18/16
In which way is the SPL an upgrade? (Legitimate question) (n/m) -
ZEngineer
17:01:50 05/18/16
Better brake air deflectors. (n/m)
not4resaleZ
17:22:47 05/18/16
Lol! (n/m)
ForceFedTT (SoCal)
20:02:22 05/18/16
21:16:44 05/18/16
Now if they only would come out with new FUCAs... With the
MixManMash
21:47:53 05/18/16
