TwinTurbo.NET: Nissan 300ZX forum - Much warmer ambient temps will still affect coolant and oil
Subject Much warmer ambient temps will still affect coolant and oil
Posted by Polish on May 04, 2016 at 4:52 PM
  This message has been viewed 475 times.
In Reply To With engine temps at 190 degrees does it matter where u live posted by LivinTheDream on May 04, 2016 at 02:44 PM
Message temps to a degree, and certainly how well the car's cooling systems can keep them at optimal levels. Engine oil plays a big part in cooling the engine, and it can break down under high heat and heavy loads, which is what our engine is all about.
A heavier weight oil is much more stable and resistant to oil shear. A lighter weight oil in super hot temperatures would experience more oil shear, thinning out the oil and offering less protection. If left unchanged, it will eventually thicken up again, but in the form of sludge and cause eventual engine seizure. That is just the extreme worst case scenario caused by severe negligence though. Anyone changing out their oil regularly will be fine, but I still do believe our hot engines benefit from heavier weight oil, especially later on in their life when you want the least amount of ware possible.
