TwinTurbo.NET: Nissan 300ZX forum - I'm using 6" long, 1.5" high hard rubber spacers (4" wide)
Subject I'm using 6" long, 1.5" high hard rubber spacers (4" wide)
Posted by Gordo 93TT Daytona on April 18, 2016 at 10:57 AM
  This message has been viewed 349 times.
In Reply To I usually used spacers to the normal jacking points. posted by BlackholeZ on April 17, 2016 at 08:15 PM
Message Two (2) on each side seems to work fine. The key is to NOT place any weight on the what looks like the forward section of the pinch weld, but is actually the fender lip that extends between the wheel well and the front door seam. e.g., all spacers should be located to the rear of the front door gap supporting the unibody. When you see buckled fenders its because a jack or lift arm was place under the forward fender area.
To be safe, however, I've ordered a set of 3" high spacers w/ 1/2" deep slot cut for pinch weld and will use three (3) per side.
_________________________________________________
