TwinTurbo.NET: Nissan 300ZX forum - Engine break in - oil cooler bypass
Subject Engine break in - oil cooler bypass
Posted by tiale11 on November 03, 2015 at 12:27 PM
  This message has been viewed 704 times.
Message For those of you that have broken in your engine with the stock oil cooler feed port blocked off...
Did you notice reduced oil filtration/increased bearing wear?
I am trying to figure out if the combination of cold start up and high oil pressure causes the oil filter bypass valve to open up undesirably
