TwinTurbo.NET: Nissan 300ZX forum - Power Steering Rack removal + Speciality-Z Oil Pan
Subject Power Steering Rack removal + Speciality-Z Oil Pan
Posted by Carlos Ramirez on August 17, 2015 at 12:50 PM
  This message has been viewed 1501 times.
Message So I was concerned doing this job in the garage at home with a speciality-Z oil pan on the car, I figured have some clearance issues and have to resort to dropping the cross member instead. But while the smaller 2 lines that are near the steering column are harder to reach because of pan it is doable and besides the mess of dealing with a steering rack can be easily done.
You have to remove both of the small hardlines from steering rack
Disconnect the 2 larger lines and then rotate rotate the assembly out. This of course in addition to removing the tie rod ends, the wheels and etc.
Its a dirty job really with all the fluids that tend to go everywhere but not to bad.
I am still in progress of putting the new back on I hope I get the steering wheel straight :-)
20150815_141004
