TwinTurbo.NET: Nissan 300ZX forum - One thing you can use instead is a high temp loctite
Subject One thing you can use instead is a high temp loctite
Posted by BlackholeZ on June 21, 2015 at 3:22 PM
  This message has been viewed 325 times.
In Reply To rear caliper bolts backed out..installed with anti seize!! posted by LivinTheDream on June 20, 2015 at 12:08 PM
Message It's designed to seal the threads to prevent corrosion, and then once you break it loose, it is a lubricant to help the bolt come out easily. I'd get their high temp blue.
But really I'd say that there is no issue with anti seize. Probably just missed them.
-Dan
VTC Solenoid Caps and install instructions.
"Capitalization is the difference between helping your Uncle Jack off a horse, and helping your uncle jack off a horse."
"'she' also likes to swap since I think I am going to need to give her to woody again." - Dvlhntr
"full alphabetic boost mode" - ChristopherTheOne
" Purrs like a sexually satisfied black panther." - BigTDogg
"Two oil eating, angry, spinning triangles of death." - turtleboy on rotary engines
