TwinTurbo.NET: Nissan 300ZX forum - I use anti seize on all of my exhaust, suspension and brake
zgene4
on June 20, 2015 at 4:59 PM
rear caliper bolts backed out..installed with anti seize!!
posted by LivinTheDream
on June 20, 2015 at 12:08 PM
Hardware and torque to the low end of factory specs. I've never had anything back out on me aside from some loose exhaust bolts after a few heat cycles.
"You are an idiot." - ni[x]it (n/m)
LivinTheDream
12:08:41 06/20/15
All things being equal ? Probably not.
ttz'in (norcal)
15:57:22 06/20/15
I use anti seize on all of my exhaust, suspension and brake -
zgene4
16:59:18 06/20/15
Same here, mid torque range though. (n/m)
ttz'in (norcal)
19:51:48 06/20/15
Why is anti-seize being used? Not needed. All the cars
jzack
22:08:54 06/20/15
The OEM Brembo's on Subaru's would routinely have
zgene4
13:31:52 06/21/15
Re: rear caliper bolts backed out..installed with anti seize!!
ttz'in (norcal)
13:48:53 06/21/15
One thing you can use instead is a high temp loctite
BlackholeZ
15:22:47 06/21/15
bolt material? I had a similar issue with downpipe nuts
19:46:05 06/21/15
^ Agree ^ (n/m)
ttz'in (norcal)
00:01:21 06/22/15
If you used a lot then yes. There should only
John (MD)
09:14:43 06/22/15
i was rather gracious.. hmmmmm thank you guys (n/m)
LivinTheDream
22:14:07 06/22/15
You may have over-stressed the fasteners and stretched them
LitlElvis
10:20:23 06/23/15
How do you determine the proper torque
ZXRider
10:54:57 06/23/15
The OP said 38 was the upper limit (28-38ftlbs)
BlackholeZ
12:00:16 06/23/15
haha reading comprehension 101 owns me
ZXRider
12:20:59 06/23/15
There are some rules of thumb
BlackholeZ
12:59:00 06/23/15
