TwinTurbo.NET: Nissan 300ZX forum - Should water pumps have no shaft play at all? (n/m)
LivinTheDream
on May 30, 2015 at 5:10 PM
Mine doesn't wobble either....only thing from the old setup
posted by jzack
on May 30, 2015 at 02:39 PM
Check this video guys I just need some more opinions:
LivinTheDream
00:07:58 05/30/15
When you put your cell between the fan and the engine
Eagle7
01:16:55 05/30/15
how do you keep your fan so bright white? whats the secret?
Jiro
09:53:04 05/30/15
bright white blades are easy just costly...$100 (n/m)
LivinTheDream
11:28:55 05/30/15
I'll go out on a limb and say it's normal (!)
OverZealous (CT)
10:07:20 05/30/15
jzack
14:39:07 05/30/15
Should water pumps have no shaft play at all? (n/m) -
LivinTheDream
17:10:02 05/30/15
None. Are you using a Nissan pump? (n/m)
19:36:31 05/30/15
Got it from SZ I assume yes. but it has slight shaft play
LivinTheDream
06:31:59 06/01/15
How tight do you have the water pump belt? I found out the
Zuberman
09:01:07 05/31/15
That's only an issue on non-oem pumps
BlackholeZ
23:06:07 05/31/15
Just want to make sure I understand you, Dan: are you saying
Zuberman
14:28:35 06/01/15
The belt has to be tight
BlackholeZ
21:45:25 06/01/15
hmmm. will tighten some more and get back to you.
LivinTheDream
01:10:23 06/02/15
does the belt squeal? If not then you don't need it tighter (n/m)
BlackholeZ
02:36:14 06/02/15
..no squeal :( why me...sigh (n/m)
LivinTheDream
17:27:51 06/02/15
belt is fine. started with it lose enough to screech on
LivinTheDream
06:35:16 06/01/15
Gregs answer inside: (Its normal) :)
LivinTheDream
18:30:07 06/02/15
Ha! Do I get a gold star for saying it was normal up front? (n/m)
OverZealous (CT)
18:31:03 06/03/15
Re: Ha! Do I get a gold star for saying it was normal up front?
Zuberman
01:08:10 06/06/15
Ok, but didn't you say there are ones that don't wobble? (n/m)
Zuberman
01:09:08 06/06/15
