TwinTurbo.NET: Nissan 300ZX forum - After opening up the two outer holes, and using a flathead
Subject After opening up the two outer holes, and using a flathead
Posted by PiotrC70 on May 23, 2015 at 5:50 PM
  This message has been viewed 540 times.
In Reply To Neither. Bumper has never been replaced. I have a scuff on posted by PiotrC70 on May 23, 2015 at 10:47 AM
Message to pry some of the other stuck bolts into place, we got things to fit. As picky as I am, I'm not all that impressed with fitment. If the material was easier to work with and flexible, we could get things more snug but there is zero wiggle room. I've never had an aftermarket bumper (besides JSpec front) Just my observation that if the mufflers were removed, you can get in into place much easier and in their current state, my SZ exhaust touches.
For now, had to bend the bracket up since there is zero flex w/out chipping the bumper. mufflers will definitely need to come off to avoid scratches.
Drivers side just below the tail lamp is a small gap that can't be pulled in.
Hard to see but the body sticks out a few mm further than the bumper.
Better (and worse) view due to the flash making it seem bigger than it is.
PS has a 2mm lip transitioning from the fender to bumper. I was able to get this down to about 1mm but it's still noticeable.
Top view of the 2mm lip
You can clearly see the corner lip that I mentioned on the drivers side.
1993 TT. R.I.P. 09.15.2010
