TwinTurbo.NET: Nissan 300ZX forum - To prevent oil pressure spikes.
Subject To prevent oil pressure spikes.
Posted by Wingzerro93 on May 12, 2015 at 9:25 AM
  This message has been viewed 393 times.
In Reply To Z1 Full Flow Oil Cooler kit question posted by Justin (Bayonne, NJ) on May 11, 2015 at 08:03 PM
Message Some engines experience high oil pressure spikes which are normally bled off through the oil cooler lines and also the restrictor by the oil cooler. Rather than capping it off and promoting this spike, Z1 designed the bypass suppliment kit using the same restrictor and simply bleeding it off into the pan. This maintains close to factory oil pressure by recreating the same restrictions as when the engine is set up in stock format.
