TwinTurbo.NET: Nissan 300ZX forum - Couple random painting questions.
Subject Couple random painting questions.
Posted by PiotrC70 on May 09, 2015 at 11:27 AM
  This message has been viewed 360 times.
Message For those that painted their Z, here's a few randoms:
Door Handles: They're out, but do you go further and disassemble the handle from the spring assembly so you can get behind/under the handle, or leave it in it's normal position and paint around as best as the painter can?
Side Mirrors: They're out as well as mirrors removed but do you separate the 2 sections and remove the motor assembly or leave it all as one piece?
Gas Tank Lid: I've removed it so I can sand behind it, but can't figure out if the metal shim that surrounds the fill hole unscrews so I can maximize on painting that area or if you leave it and tape around the bushing assembly?
This last one is just misc... Fog light buckets: I have ducts going in so do you remove the fiber glass bucket assembly completely and remount the crash bar, or just cut the bucket off since the bolts go through it?
Thanks!
1993 TT. R.I.P. 09.15.2010
