TwinTurbo.NET: Nissan 300ZX forum - center console or top of transmission tunnel
Subject center console or top of transmission tunnel
Posted by zromtech on April 14, 2015 at 1:20 PM
  This message has been viewed 244 times.
In Reply To Where to mount an accelerometer/daq? posted by BlackholeZ on April 12, 2015 at 03:39 PM
Message You want it firmly attached to somewhere flat. I data logged accelerometer data (not from an LMA-3 though), and found inside the center console was the flattest place in the car. I'm not sure how useful 2-axis data are though... any deviation from flat will throw off the numbers due to gravity, as can vibrations (depending on the sampling rate and filtering of the accelerometer signal). You need 3-axis to properly determine the 'up' vector and the true longitudinal/lateral forces.
