TwinTurbo.NET: Nissan 300ZX forum - I think the closed throttle switch output is used to
Subject I think the closed throttle switch output is used to
Posted by LitlElvis on March 12, 2015 at 10:21 AM
  This message has been viewed 468 times.
In Reply To Some info on the operation of the TPS. posted by DVDBURN (MD) on March 11, 2015 at 11:17 PM
Message activate an open loop idle condition in the ECU which ignores TPS related load corrections at idle only and negates TPS voltage changes that occur between cold start and operating temp. This was a nice little trick that Nissan did to stabilize the idle and I would like to try to duplicate it with my AEM (AEM's base Z32 configuration runs idle off of TPS voltage only in open-loop and is a PIA to work with when the voltage creeps around).
