TwinTurbo.NET: Nissan 300ZX forum - Which EMS can write specifically to an individual injector?? (n/m)
RZturbo
on February 20, 2015 at 8:41 PM
What EMS?
posted by bartz32tt
on February 20, 2015 at 12:06 PM
Rod bearing service life:a long-term review of my experience
Ash's Z
06:24:41 02/20/15
Why not just run less aggressive timing to lower
The Devils Z
08:14:52 02/20/15
I've been running 18 degrees of total advance at full load
Ash's Z
11:54:37 02/20/15
You can have gradual detonation without hurting
The Devils Z
19:26:49 02/20/15
i use the JS knock box you can hear knock that you can not
Dane (Houston)
18:52:13 02/23/15
Re: Mobil 1
Hiram
08:40:41 02/20/15
Hmm. (n/m)
BannonZ
09:02:53 02/20/15
I dont think Ash mentioned anything about the EP oil
ZXoltan
10:44:19 02/20/15
C&D Recommends Changing Your Oil at Least Twice a Year
flashstar
11:53:40 02/20/15
You're correct. Oil's life is measured not only by mileage,
Hiram
00:11:56 02/21/15
I change the engine oil every 3K miles bud. Keep in mind,
Ash's Z
11:57:26 02/20/15
Wear could be worse on the 6th in general but good oil
flashstar
12:01:30 02/20/15
So if Mobil 1 15K mile oil falls back to a manufacturer's
Hiram
13:37:49 02/20/15
people say all sorts of crap based on nothing but suspicion (n/m)
13:52:49 02/20/15
Truth! (n/m)
Barry (NJ)
14:20:06 02/20/15
my life at work .. probably the best comment I have
The Devils Z
19:20:22 02/20/15
I would quit a job like that, lol (n/m)
Hiram
23:47:28 02/20/15
I wouldn't deny someone's experience with a product, but
Hiram
00:02:18 02/21/15
it has nothing to do with fine print vs marketing print
13:11:42 02/22/15
I will tell them to tell their mechanics what you said. (n/m)
Hiram
02:21:30 02/26/15
Like I said, best of luck :) (n/m)
Hiram
13:41:37 02/20/15
BTW, I'm not using Extended Performance lube. (n/m)
Ash's Z
16:15:27 02/20/15
Understood. Good luck with it. (n/m)
Hiram
23:48:16 02/20/15
Do you know if shimming the oil pump pressure relief valve
ZXRider
10:47:52 02/20/15
There was no indication of that being the case. I caught
Ash's Z
15:27:57 02/20/15
Do you think this feeds back to #6 running hotter?
Schmeal (NV)
11:05:23 02/20/15
Your proposal is based on piston sieze which I am sure is
Ash's Z
16:18:57 02/20/15
One of the best "knock boxes" out there...
kickerzx
17:53:30 02/20/15
Like the post and timely....
Z ONLY1
11:11:25 02/20/15
Is your OEM knock control in spec?
zromtech
11:48:05 02/20/15
even if this is true - the OEM knock control only works
The Devils Z
19:15:35 02/20/15
His thread on the subject back in 2013...
Ted (92TT)
20:26:13 02/20/15
Re: even if this is true - the OEM knock control only works
zromtech
11:08:16 02/21/15
Interesting
maglito
21:51:36 02/23/15
What EMS?
bartz32tt
12:06:06 02/20/15
Which EMS can write specifically to an individual injector?? (n/m) -
RZturbo
20:41:28 02/20/15
Most decent ones can... (n/m)
kickerzx
05:45:08 02/21/15
Do you have a UOA done at each oil change?
Tanley
18:49:33 02/20/15
I run 20W50
RZturbo
20:54:40 02/20/15
Do you run 20W50 in the winter also? (n/m)
sak01
11:02:20 02/21/15
The z is normally garaged
RZturbo
20:35:26 02/21/15
I really like M1 5w50 (n/m)
Polish
02:33:21 02/22/15
Re: Rod bearing service life:a long-term review of my experience
Bigwill837
08:25:10 02/21/15
You went with 0.0015" bearing clearance
-Grimm-
09:56:13 02/21/15
seems a bit tight to me
aliaZ
17:43:19 02/22/15
2nd (n/m)
John (MD)
15:36:57 03/01/15
Ash, exactly which oil are you using? Any sampling?
SMAZ (OKC)
12:23:50 02/22/15
Thanks for sharing your findings Ash! (n/m)
maglito
21:52:47 02/23/15
