TwinTurbo.NET: Nissan 300ZX forum - That is accurate for "stock" base fuel pressure, however
Subject That is accurate for "stock" base fuel pressure, however
Posted by induetime on September 22, 2014 at 9:43 PM
  This message has been viewed 388 times.
In Reply To I am not an expert... posted by Bigwill837 on September 22, 2014 at 11:51 AM
Message You can get a fair amount more out or the injectors by upping the base fuel pressure. Some to the fastest (ETS for example) R35 GTRs are running smaller injectors with 90ish base pressure on a mechanical fuel pump. The fuel system gets more complicated the higher up you go, but the fuel atomizes better the higher you go as well, to a point.
~Induetime~ "Lag Less"
First Stock Turbo to break 500WHP on boost alone.
New track car project "Diseaze":
http://arizonazproject.wordpress DOT com
Custom fabrication for the Z32: search QFAB on Facebook
More custom fabrication: search FuturFabrication on Facebook
