TwinTurbo.NET: Nissan 300ZX forum - Swapped in SS turbo oil feed line on RH BUT!!
Subject Swapped in SS turbo oil feed line on RH BUT!!
Posted by LivinTheDream on September 18, 2014 at 7:26 AM
  This message has been viewed 255 times.
Message Yes I did it with the engine in and without the removal of my SZ 3" DP's or anything else. BUT based on the pics I've seen my line is alot shorter than all others. For example: [ http://twinturbo.net/net/viewmsg.aspx?forum=general&msg_id=2448810&forum=general&dtSearch=4 ]
I put at thermo sleeve over it and its not touching the turbine housing but it is slightly touching the outer coolant banjo bolt and the closest point to the turbine housing has about 3/4 to 1" gap. Do you guys think its too close for comfort with possible issues.
"torque gets you off the line...& hp gets you over the line." -
TTKeeper
