With a typical throttle the rate of increase to open area increases up to the 50% throttle opening, after this point the rate of increase to open area decreases up to 100% throttle opening. With an off center throttle cable pulley you can overcome this on half of the effect, with a shaped throttle pulley you can completely overcome this. But then comes the issue of boost, with a throttle by wire system (with a capable engine management system) you can program a ecu to compensate for the turbos ramping up too quickly. Basically this would be good for traction control, hitting the throttle in a corner you don't really want the turbos to kick in so quickly. Throttle by wire would allow you to basically make the accelerator pedal into a torque selection device, giving the car a generally "responsive feel" at the expense of removing the maximum available power. Not to take away from your question but additionally my question is: why not throttle bodies BEFORE the turbos?
____________________________________________________ "The dreaded 2nd windshiled wiper swipe when you turn it off its almost like tis showing you that it's boss, and it doesn't have to stop when you tell it to :("-College Boy (discussion on ptu relocation) "No good reason to put it there anyway. -Bernie (NoVA) False -vorpalZ False. -Bernie (NoVA) You're correct, there are 3 good reasons -vorpalZ False. -Bernie (NoVA) Wow, right again, just remembered another, make that 4 -vorpalZ" XD |
