TwinTurbo.NET: Nissan 300ZX forum - A common head gasket failure is the loss of coolant
Subject A common head gasket failure is the loss of coolant
Posted by JMartz on July 11, 2014 at 2:23 PM
  This message has been viewed 193 times.
In Reply To Overheating troubleshooting. posted by Antihero on July 11, 2014 at 09:31 AM
Message no where to be found. If your coolant is disappearing, not showing up a a green leak of fluid on your garage floor, abd you car overheats, then you can suspect the head gasket. There is a chemical that will change color if combustion gases get in the coolant. I have never used it but will next time faced with this issue.
Many other things can cause overheating. head gasket is the one to overrule asap.
