TwinTurbo.NET: Nissan 300ZX forum - One thing that helps with the startup drain is running
Subject One thing that helps with the startup drain is running
Posted by TriniTT on July 02, 2014 at 6:30 PM
  This message has been viewed 237 times.
In Reply To Imo, it is good idea to upgrade the alternator especially posted by HighPsi (NorCal) on July 02, 2014 at 05:17 PM
Message an oem relay switch like the Volvo one Tim (Woody75) is using. I'm using the same dual relay switch and it's the perfect one for the job imo. I'm using a vw thermostatic switch that kicks each speed on and off at specific temps. This almost identically mimics the operation of the clutch fan, but can be even more efficient since you're getting a much higher cfm at idle and lower rpms.
Cheers,
JBrobst
