TwinTurbo.NET: Nissan 300ZX forum - PSA: There is a drain plug low on each side of the block
Broke_as_****
on May 16, 2014 at 9:35 PM
Failed Turbo Analysis (long with pics)
posted by OverZealous (CT)
on May 16, 2014 at 08:13 PM
You can see it in the ninth pic, between the alt bracket and the motor mount. Put a huge pan under it and remove while it's still up right to get most of the coolant out.
OverZealous (CT)
20:13:02 05/16/14
Good idea on replacing both. (n/m)
Evan_Wright (Ca)
21:15:01 05/16/14
Yes, an expensive but seemingly good decision. (n/m)
OverZealous (CT)
07:55:02 05/17/14
PSA: There is a drain plug low on each side of the block -
Broke_as_****
21:35:16 05/16/14
Humbling. Thanks!
OverZealous (CT)
08:03:56 05/17/14
Are you replacing the rear main seal?
ZaXxon
05:50:48 05/17/14
Doubtful as it would be the second time.
OverZealous (CT)
08:02:38 05/17/14
Thanks for the pic ZaXxon... 2 questions:
ZXoltan
10:52:32 05/17/14
No vibrations. It's a 1/2" NPT plug I got from amazon
ZaXxon
17:00:06 05/17/14
Oil Sample Analysis is IN. Mostly normal result.
OverZealous (CT)
15:32:00 05/17/14
Is this the first oil analysis you have run on the car?
Tanley
21:28:07 05/17/14
Your idea on oil weight is a bit off. Doesnt matter if he
LivinTheDream
11:51:24 05/18/14
Please explain how running 20W-50 could be an issue?
Tanley
13:36:34 05/18/14
Is this my first oil analysis? Yes.
OverZealous (CT)
21:07:49 05/18/14
Interesting, I can't remember from your earlier posts,
Tanley
22:18:34 05/18/14
I'm making a real time call depending on current condition. (n/m)
OverZealous (CT)
09:07:42 05/19/14
Does your car have a turbo timer?
bartz32tt
08:05:54 05/18/14
what quality of oil the previous owner used would say alot
LivinTheDream
11:58:04 05/18/14
No, I don't have a turbo timer but I cool down every time.
OverZealous (CT)
21:16:13 05/18/14
Position of the rust on manifold and heat shield
BlackholeZ
16:48:18 05/17/14
No. And that's not the position where water would pool.
OverZealous (CT)
19:37:30 05/17/14
"Pooling" is not a good descriptor
ZXoltan
07:59:43 05/18/14
This seems a reasonable explanation to me. (n/m)
OverZealous (CT)
21:19:37 05/18/14
The rust on the inside of the shield is common...
ConVerTT
09:10:54 05/18/14
On both left and right sides?
OverZealous (CT)
21:20:56 05/18/14
Yes
ConVerTT
23:37:15 05/18/14
Looks ok from what I see. I'll check more tonight. (n/m)
OverZealous (CT)
09:10:20 05/19/14
Are you running a full flow oil cooler?
BarryGZX
20:05:24 05/19/14
