TwinTurbo.NET: Nissan 300ZX forum - TT oil pump relief spring data >>>
Subject TT oil pump relief spring data >>>
Posted by LitlElvis on September 10, 2013 at 2:56 PM
  This message has been viewed 991 times.
In Reply To Re: That's great information but... posted by Tech@EPR on September 10, 2013 at 01:17 PM
Message Here's some data I took from a TT oil pump relief spring assembly.
Piston OD: 0.628"
Spring:
Length (inches).....Load (lbs).....PSI*
2.250....................0.0....................0
2.000...................12.9..................41.8
1.750...................27.5..................88.9
1.625***.............35.0.................113.0
1.500...................42.4.................136.9
***At 1.625" the relief window becomes exposed and begins to allow oil to bypass internally.
*PSI is the oil pressure required to compress the spring to the stated length/load and is calculated from the piston's area.
The low pressure, primary relief valve for a TT's overall engine oil pressure is in the oil filter tree and allows excess pressure to flow through the oil cooler and then back to the sump. I have not tested this spring assembly.
