TwinTurbo.NET: Nissan 300ZX forum - No problem. Both AP and Stoptech's templates can be printed
Subject No problem. Both AP and Stoptech's templates can be printed
Posted by MixManMash on May 12, 2013 at 11:04 PM
  This message has been viewed 140 times.
In Reply To Thanks! I'm sure I wouldn't be unhappy with the stoptechs posted by TriniTT on May 12, 2013 at 08:50 PM
Message off. Make sure in Acrobat reader, the setting is not for fit to page, but normal size. Double check the printed measurements. Glue it on to cardboard and cut out the part you need. You can then use the template on your wheels to see if the caliper will clear.
As well, AP has a ton of different kits even in the 13" size (some with 4 piston calipers, others with 6 piston, some with single piece rotors, other with 2 piece rotors). Make sure you get the template for the correct calipers.
