TwinTurbo.NET: Nissan 300ZX forum - I use ASP from IPP. No problems yet... (n/m)
evan_aggie
on August 23, 2012 at 12:25 AM
As much as i hate supporting ams . I will say this ....
posted by ztunerz
on August 22, 2012 at 11:18 PM
RDZ underdrive pulley... review?
AHos(Chicago)
18:30:32 08/22/12
I can tell you one thing, Unorthodox is not great either
Jayru
21:13:48 08/22/12
knockoff? (n/m)
BoneZ (MD)
21:17:24 08/22/12
IDK I never had a problem with any of the UR pulleys I used (n/m)
white22sky
21:25:55 08/22/12
Pictures please.
21:29:53 08/22/12
Pics to come, have to dig through the footage. (n/m)
Jayru
08:20:32 08/23/12
One more reason to buy an ATI damper. (n/m)
Piranha
22:02:11 08/22/12
Not a good reason sorry. It was easy enough to find
ztunerz
23:12:00 08/22/12
Not a good reason? lol (n/m)
Piranha
19:27:48 08/23/12
not worth the money unless you're building a monster (n/m)
ali300zx
11:54:14 08/24/12
Same thing used to be said about 3" exhaust, dual intakes
Piranha
13:01:37 08/25/12
You would spend 500 bux rather than 10 minutes marking a
ztunerz
12:00:17 08/24/12
Yes and to protect against torsional vibration that our
Piranha
13:04:19 08/25/12
I'd like to see some data pertaining to our motors please (n/m)
ztunerz
22:47:19 08/25/12
I was primarily refering to the timng mark and your reason
ztunerz
22:49:05 08/25/12
Purchased from where? (n/m)
ConVerTT
22:08:47 08/22/12
I've never had any issue with mine (n/m)
BlackholeZ
23:05:11 08/22/12
It was off about 50 deg to the left of where it should be
ztunerz
23:14:38 08/22/12
50 degree to the left?? I am having the same problem here
tt_703
06:57:07 08/23/12
Do you have an UR pulley? I would say check TDC
Jayru
08:19:23 08/23/12
Re: Do you have an UR pulley? I would say check TDC
tt_703
10:08:22 08/23/12
Why do you need to remove the pulley ? (n/m)
ztunerz
23:58:26 08/23/12
reverse the timing gun pickup on the wire loop (n/m)
20:48:42 08/24/12
weird I've never had a problem with mine (n/m)
RobZ32
12:30:35 08/23/12
ztunerz
23:18:51 08/22/12
I use ASP from IPP. No problems yet... (n/m) -
evan_aggie
00:25:50 08/23/12
Second (n/m)
ZXoltan
08:03:44 08/23/12
My timing mark was off quite a bit on the ASP pulley.
Mike TDK (NoVA)
12:35:24 08/23/12
Observed the same (n/m)
ztunerz
14:18:12 08/23/12
As far as I can tell...
AHos(Chicago)
01:05:27 08/23/12
Tell that to this GTR owner:
08:43:00 08/23/12
Wow.. Yup like I said - don't trust their manufacturing. (n/m)
AHos(Chicago)
10:16:47 08/23/12
AMS found a way to lose more weight
Got Z?
13:26:55 08/23/12
Impressive (n/m)
ztunerz
14:17:22 08/23/12
Unless someone has a UR for sale.. I'll be the guinea pig.
AHos(Chicago)
01:08:36 08/23/12
Why not UR ? Is rdz that much cheaper ? (n/m)
ztunerz
01:32:31 08/23/12
About $100 less.
AHos(Chicago)
10:19:18 08/23/12
Agreed, just checking since i did not know the price. (n/m)
ztunerz
14:16:40 08/23/12
It, also, seems to be made of the same aluminum as UR (n/m)
AHos(Chicago)
11:20:07 08/23/12
According to .............. ? (n/m)
zellamay
15:06:06 08/23/12
I was just going off of the websites...
AHos(Chicago)
17:48:04 08/23/12
I will never understand why people...
Only1Z
17:16:50 08/23/12
My stock pulley was trashed.
Jayru
17:34:23 08/23/12
Jason, maybe an unbalanced crank for high-hp applications?
vulcanrush
19:23:24 08/23/12
Z crank is not externally balanced. If that was the case
ztunerz
23:54:10 08/23/12
sorry, Harry, perhaps undampened is more accurate?
vulcanrush
13:04:37 08/24/12
eh.... its actually a pretty good mod
Antihero
09:25:25 08/24/12
yeah (n/m)
ztunerz
00:08:29 08/25/12
It's a proven mod and relatively cheap. What's not to like?
Inzane
12:12:55 08/25/12
Because its a cheap power mod and the Z32 never spins
Piranha
13:07:46 08/25/12
Ever wonder why we rarely have issues with our main bearings
ztunerz
22:53:15 08/25/12
Mine works fine. (n/m)
DbestiZ1
06:06:08 08/24/12
