TwinTurbo.NET: Nissan 300ZX forum - AVC-R install question - ground wire setup
Subject AVC-R install question - ground wire setup
Posted by awesom-o on July 16, 2012 at 10:38 AM
  This message has been viewed 413 times.
Message Howdy all -
I removed my sub-harness, which had a direct tap in extension for the AVC-R setup. Quick question from the wiring diagram in the AVC-R instructions:
When I tap into the ground for the install, should the connection between the two wires be broken? Or, should I only tie into the line at the 2 separate points leaving the original connection in tact? The install is a bit unclear, and searching has been unproductive.....
See below pic, should I cut the line and tie off where the arrow is or only tap into that line with both grounds?
AVC-R
