TwinTurbo.NET: Nissan 300ZX forum - KYB + Ground Control assembly questions
Subject KYB + Ground Control assembly questions
Posted by nicky_z32 on July 01, 2012 at 11:07 AM
  This message has been viewed 970 times.
Message Hi guys, I'm having some doubts in assembling my KYB AGX and Ground control Coilover setup.
First these are the parts I'm assembling:
Photobucket Pictures, Images and Photos
Per instructions it says that the o-ring must be installed here, (what's the purpose of an o-ring here?). I'm not sure if the o-ring should go all the way down, because in the picture it's resting in a little notch:
Now comes the sleeve and adjustment perch, the angled side should be installed facing downwards, and by doing so, it actually pinches the o-ring, and doesn't fit flush, do I have to grind anything to make it go all the way down?
Now the spring, a solid bushing that goes in the shock shaft, aluminum solid mount,  pillow ball mount, another solid bushing that centralizes the shock shaft in the pillow ball mount and nut:
Since I'm not using the stock rubber mounts, do I still have to cut/modify /install the stock rubber bump stops? I'm I installing something incorrectly? This is a really important part of our cars and I don't wanna mess anything up.
Thanx a lot for any info!
