TwinTurbo.NET: Nissan 300ZX forum - I'd worry more about having a capable air compressor and
Subject I'd worry more about having a capable air compressor and
Posted by Evan_Wright (Ca) on June 23, 2012 at 11:04 AM
  This message has been viewed 311 times.
In Reply To Good work posted by bartz32tt on June 23, 2012 at 10:49 AM
Message a way of keeping the air dry. Soda blasters are simple devices and I think they all work just fine as long as you can keep the air dry. Any moisture and you can forget about using your blaster. I have a soda blaster and a sand blasting cabinet from harbor freight. I use either with great results. I bought a 3hp 60 gallon air compressor that works well but I do notice that the soda is less effective when the pump is running. Because of this I would recommend getting a two stage compressor. Mine is dual cylinder 240v single phase but only a single stage pump. I usually take a break when the pump is running. My suggestion is to use a 60+ gallon, 3+ hp, dual stage compressor and a nice dryer plumbed to it.
