TwinTurbo.NET: Nissan 300ZX forum - Problem with the OEM fan to use as the propulsor for
Subject Problem with the OEM fan to use as the propulsor for
Posted by Ash's Z on June 13, 2012 at 9:09 AM
  This message has been viewed 302 times.
In Reply To Ash-you really should use the OEM fan to replicate what most posted by The Devils Z on June 12, 2012 at 09:21 PM
Message cooling air in this testing is that the fan clutch varies the amount of torque applied to the fan dependent on the temperature its bi-metal control spring is exposed to. This creates an additional variable in the test that will skew the results.
In this testing, we are using a fixed amount of energy input into the electric fan. The variations in the fin designs of different radiators is going to have an effect on how much air will be drawn through the ambient cooling fins, but variations in cooling fin design/densities/etc are also going to have an effect on the radiator's cooling effectiveness. The idea with this testing is to keep all of the other conditions static for all tests with the radiator itself being the only variable in the test.
Now as for what our final kit will have to offer for shrouds, we will have options for either an e-fan + shroud OR a new shroud that can be used with the OEM mechanical fan.
Enthusiasts soon understand each other. --W. Irving.
Are you an enthusiast?
If you are out to describe the truth, leave elegance to the
tailor.
Albert Einstein
