TwinTurbo.NET: Nissan 300ZX forum - Not a problem, anything I build sees boost after 20-30min
Subject Not a problem, anything I build sees boost after 20-30min
Posted by Doug71zt(CAN) on June 11, 2012 at 5:42 PM
  This message has been viewed 212 times.
In Reply To How terrible is a small amount boost break-in? posted by Coldfusown on June 11, 2012 at 04:46 PM
Message There are two schools of thought on this, I believe that moderate boost (and cylinder pressure) helps to seat the rings in a fresh build better than babying it for 500 miles.
I run 20 min high idle to establish cam wear pattern, then drive the car for 30-40 minutes at varying engine speed and load. I don't wring its neck at WOT though. Shut it down, let it cool, retorque the heads if required and change the oil/filter.
