TwinTurbo.NET: Nissan 300ZX forum - Re: Do you need an ECU upgrade with these 400+ cams?
Subject Re: Do you need an ECU upgrade with these 400+ cams?
Posted by Tech@EPR on June 10, 2012 at 7:08 PM
  This message has been viewed 199 times.
In Reply To Do you need an ECU upgrade with these 400+ cams? posted by Z-speed on June 10, 2012 at 05:47 PM
Message at best if you want to do are freshen on the heads I'd do a valve spring replacement with OEM if you keep the stock cams. Even if you upgrade to the S1s the stock springs will do fine. Issue is with over time the springs become "saggy" inadequate or loose their coil which weakens their seat and open pressures. Replacing the springs will make the engine more responsive RPM wise.
Ultimately if you are stock from head to toe...I'd just worry about bolt ons and have fun. Once you start digging into the rest of the engine is when I'd begin to invest in upgraded camshafts.
Ep Racing | Create Your Badge
