TwinTurbo.NET: Nissan 300ZX forum - Re: Poor sealing Z1 tb's and how they effect idle control...
Subject Re: Poor sealing Z1 tb's and how they effect idle control...
Posted by Stadsport (PHX) on May 24, 2012 at 2:22 AM
  This message has been viewed 238 times.
In Reply To Poor sealing Z1 tb's and how they effect idle control... posted by Evan_Wright (Ca) on May 23, 2012 at 09:01 PM
Message It definitely sounds like the TBs are leaking, and everything you're ascertaining about the idle screw, AAC not able to lower idle, 12% indicating a vacuum leak, I agree 100%
However I don't think your AAC is necessarily bad from what you've said here... did you try RAISING the idle with it? Like, set the AAC to 60% and see if the idle increases? It does bottom out around 12% for most cars, but as you know, being that low just indicates that there's more air entering than it can compensate for.
