TwinTurbo.NET: Nissan 300ZX forum - Re: A ATI damper is pressed fit, Which makes it a PITA to remove
ouikikazz
on May 18, 2012 at 9:30 PM
posted by toykoz32
on May 18, 2012 at 08:25 PM
sigh...i had to use a harmonic balancer puller...worked great but should of known NONE of the bolts that came with the puller worked had to source my own :(
ATI Dampner WTF
ouikikazz
17:19:56 05/18/12
It may throw the balance off.. but its so small..
KongZTT GT28RS MD
17:28:09 05/18/12
Should be fine.
ZXoltan
18:08:06 05/18/12
***should*** be fine wouldn't sit comfortably with me
fuzzymonkey
18:22:49 05/18/12
I've seen plenty of chipped stock balancers that never had
aliaZ
19:20:01 05/18/12
Ha , I like that ^^^ (n/m)
Xteam300TT (South Tx )
22:41:11 05/18/12
Re: ATI Dampner WTF
MaxxAction
18:35:21 05/18/12
Or you can use a small film of anti-seize (n/m)
KongZTT GT28RS MD
18:50:23 05/18/12
2nd (n/m)
aliaZ
19:17:34 05/18/12
Re: Or you can use a small film of anti-seize
MaxxAction
19:21:47 05/18/12
Highly doubt you caused any issue. I don't think that could
Jkova300z
18:36:33 05/18/12
no you can't balance an ATI
aliaZ
19:17:09 05/18/12
I think you contradicted this statement up above, Don :-P (n/m)
ZXoltan
06:51:53 05/19/12
toykoz32
20:25:24 05/18/12
Re: A ATI damper is pressed fit, Which makes it a PITA to remove -
ouikikazz
21:30:56 05/18/12
That one pictured didn't come with the correct bolt either
toykoz32
21:58:05 05/18/12
Re: That one pictured didn't come with the correct bolt either
ouikikazz
22:09:03 05/18/12
You could grind off a similar amount on the other side if it
turtleboy
22:15:30 05/18/12
Thats just silly (n/m)
toykoz32
23:02:39 05/18/12
