TwinTurbo.NET: Nissan 300ZX forum - A ATI damper is pressed fit, Which makes it a PITA to remove
Subject A ATI damper is pressed fit, Which makes it a PITA to remove
Posted by toykoz32 on May 18, 2012 at 8:25 PM
  This message has been viewed 703 times.
In Reply To ATI Dampner WTF posted by ouikikazz on May 18, 2012 at 05:19 PM
Message I use this remover for the ATI and Factory
The claw type works on the aluminum pulleys.
From ATI Website:
Press fit of the hub to the crankshaft is vital to transfer harmonics to the damper assembly. Recommended press is as follows:
Crankshaft Snout Diameter
Recommended interference
1.0000" - 1.2500"
.0009" to .0012"
1.2510" - 1.3750"
.0008" to .0011"
1.3750" - 1.6000"
.0007" to .0009"
GM cranks are typically to tolerance +/- .0001". If you are using an OEM GM crank you can hone the damper hub as follows:
Big Block: hone to 1.5993" +/- .0001"
Small Block: hone to 1.2460" +/- .0001"
On all other cranks, the crank must be checked with micrometers and the hub with a dial bore gauge to verify fit. Most OEM cranks are held to +/- .0002" while most aftermarket cranks are held to +/- .0005." Hub bores are tight to accommodate aftermarket cranks and most steel hubs will require honing. Do not hone aluminum hubs.
[ http://www.atiracing.com/products/dampers/damper-instructions.htm ]
