TwinTurbo.NET: Nissan 300ZX forum - Affects ecu ignition timing, neutral 15 vs in gear 20
Subject Affects ecu ignition timing, neutral 15 vs in gear 20
Posted by Kennymonster on May 18, 2012 at 6:25 PM
  This message has been viewed 270 times.
In Reply To What's the point of the neutral switch on 5sp transmissions? posted by fuzzymonkey on May 18, 2012 at 02:49 PM
Message Properly functioning neutral switch is the only way the ecu will know it's out of gear, @ 15 degrees, which should match the timing mark of 15.
The idle changes because of this difference in ignition timing (I'm pretty sure)
