TwinTurbo.NET: Nissan 300ZX forum - extreme dry only tire recommendations
Subject extreme dry only tire recommendations
Posted by Carlos Ramirez on May 16, 2012 at 10:51 AM
  This message has been viewed 332 times.
In Reply To Need a Tire recommendation posted by Ahmed (Chicago) on May 16, 2012 at 10:13 AM
Message I like the
Falken RT-615K (I had the older RT-615 and I liked them)
Nitto NT-05 (I have them now like them better than older RT-615)
Kumho Ecsta XS . I really wanted to try these but have no real data, I hear they warm up faster which my older RT-615 which did take a sec to warm up (spun them often at the end I ended up spinning the rim off 1 of the tires and that was the reason I had to replace them).
Those are all S type Tires if you want to goto the next level you can goto an R type like maybe
Toyo RA1s or something similar but I find them to be too much of a PITA if you get caught in the rain, usually are loud especially the R888s, have to really heat them up, and finally wear out the tread fairly quickly. So I don't recommend them unless you are to the point where you have to much Torque, and can't modulate the nerve between your foot and your brain to nothing other than 100% throttle :-)
