TwinTurbo.NET: Nissan 300ZX forum - Re: Air intake temp sensor location...?
Subject Re: Air intake temp sensor location...?
Posted by Carlos Ramirez on April 30, 2012 at 10:30 AM
  This message has been viewed 1555 times.
In Reply To Air intake temp sensor location...? posted by TTZ2NV(EPTmotorsports) on April 30, 2012 at 09:37 AM
Message So in the process of installing lots of AIT sensors I have found that if you put them in plenum they tend to be affected by a heated soaked plenum.
Installing them on the intake pipe right after the filters tend to read more aggressive for example you have heat soaked your inter-coolers. We have tested with installing them on the inter-cooler pipe before the throttle body.
We have also installed them on the intake plenum using spacers to reduce heat soak.
Also remember KISS (keep it simple stupid!) don't complicate your life with 2 AITs next thing you know will be wanting to individual adjustment the duty cycle of the number 6 injectors to run it richer. OR maybe you will want to do 6 Cylinder head temperature sensors and do feedback on that. Oh wait we can't forget about a Back pressure feedback table too :-) Though I do like barometric sensors though which not many implement.
Have fun with your AEM.
