TwinTurbo.NET: Nissan 300ZX forum - The correct fix is retap w/ helicoil... but I' try Plan B >>
Subject The correct fix is retap w/ helicoil... but I' try Plan B >>
Posted by Gordo 93TT Daytona on April 21, 2012 at 8:43 PM
  This message has been viewed 248 times.
In Reply To Is a Loose Exhaust Manifold Nut ok? posted by OverZealous (CT) on April 21, 2012 at 01:04 PM
Message which would be to shim the bolt tight again. I would try to wedge the gap tight again; then secure the wedge in place.
If you can find a very wide 10 mm washer slighter thicker than the gap. With a dremel, cut out a pie shaped section just wide enough so it will slip over the bolt. Then grind a taper onto the remaining washer so that you can tap it onto the bolt where it will wedge itself tight into place. Finally, use vice grips, squeeze the outside edges of the washer to close the washer back around the bolt. If that fails, then tap it close w/ a small hammer, using a larger one on the opposite side of the washer.
You may even be able use a couple of brake line shims... anything to wedge that space tight again. It has to be fixed though b/c the heat cycle of exhaust manifolds will shake loose anything that is simply wedged in w/o being fastened in place.
_________________________________________________
