TwinTurbo.NET: Nissan 300ZX forum - The 300 degree kit is a fixed adjustment kit to match
Subject The 300 degree kit is a fixed adjustment kit to match
Posted by RICH1 on March 13, 2012 at 2:24 PM
  This message has been viewed 96 times.
In Reply To Do I need to adjust ride height? posted by weezee on March 13, 2012 at 01:23 PM
Message the drop (0.8") of the Eibach Pro kit springs. If you plan to set your ride height different than this then you will need adjustable camber arms in both the front and the back in order to get the camber adjusted properly. I had to add adjustable camber arms in the rear (in addition to the 300 degree kit) when I installed the Eibach's since I was getting excessive wear on the inside part of the rear tires.
