TwinTurbo.NET: Nissan 300ZX forum - But arent' they replacing protected fuel lines with regular? (n/m)
WhiTTe Z
on December 17, 2011 at 12:24 PM
YES - very much so. (n/m)
posted by Bernie (NoVA)
on December 16, 2011 at 07:30 PM
Finally got the guts to clean my Z and check out the damage
Beachy
15:44:32 12/15/11
I found a hood at Rockauto.com for $260
Beachy
16:02:52 12/15/11
get a used oem hood. only sensible option (n/m)
Antihero
16:25:09 12/15/11
Agreed. (n/m)
16:28:54 12/15/11
yup, i got my aluminum one for 80$ used. (n/m)
Z32TT-R
22:30:48 12/15/11
ill fitting steel (n/m)
16:28:39 12/15/11
and heavy (n/m)
zgene4
20:46:23 12/15/11
Any idea what the root cause of the fire was? (n/m)
16:52:51 12/15/11
You mean...
madscientist222
17:53:08 12/15/11
Autozone fuel hose and clamps. (n/m)
Beachy
18:16:40 12/15/11
I am actually carrying an extinguisher now because of this,
Jkova300z
19:58:49 12/15/11
One of the first things I bought for my Z. (n/m)
arrowenterprises
22:02:39 12/15/11
I was running autozone line and OEM clamps
alpha_omega16
20:55:02 12/15/11
OEM line is slightly less in diameter than than most generic
Gordo 93TT Daytona
21:41:21 12/15/11
Craigslist. There are always someone parting
zellamay
17:06:04 12/15/11
lol what a coincidence.
Evan(CA)
18:16:19 12/15/11
Yea, the memory is going. I guessed at the $125 figure.
zellamay
00:21:58 12/16/11
Re: Finally got the guts to clean my Z and check out the damage
Nis300owner
17:24:15 12/15/11
Definitely stay with an OEM hood.
pa300
18:26:56 12/15/11
CmyZ
19:23:26 12/15/11
^ Is fuel hose and worm style clamps from Autozone/ Pepboys
Jkova300z
20:04:00 12/15/11
From personal experience:
MrOzzie5183
20:27:13 12/15/11
I run the 300degree setup, so if I go all OEM
Jkova300z
20:40:12 12/15/11
Thats what I would use
MrOzzie5183
20:50:08 12/15/11
absolutely not ok. fix that. (n/m)
Antihero
22:19:20 12/15/11
The over the counter fuel line is typically NOT rated for
22:55:24 12/15/11
You can find some there, but it won't fit as good as OEM (n/m)
08:09:06 12/16/11
Use FI hose rated at SAEJ30R9; not gas line SAEJ30R6
Gordo 93TT Daytona
07:35:06 12/16/11
Forgot to add: When in doubt... Go w/ OEM line and clamps
Gordo 93TT Daytona
07:39:05 12/16/11
and it must be correct metric size (n/m)
Antihero
16:36:38 12/16/11
Re: and it must be correct metric size
CmyZ
20:34:29 12/16/11
Nauseating feelings of the fire my Z went through @ Vina-Wreck
samsungZ [Houston]
21:37:11 12/15/11
Give me a call when you get to Austin. I'm sure I have a
sfarrah
21:54:35 12/15/11
I have a mint hood, but that is a long way to ship it... (n/m)
na300zx (OH)
23:02:23 12/15/11
Yep, your hood is definitely "Toast" :-P (n/m)
ZXoltan
07:37:51 12/16/11
Carbon Fiber requires a torch to burn, Aluminum melts faster (n/m)
Red Hawk (CO)
12:51:20 12/16/11
Are these fuel hoses legit?
WhiTTe Z
18:33:29 12/16/11
19:30:13 12/16/11
But arent' they replacing protected fuel lines with regular? (n/m) -
WhiTTe Z
12:24:25 12/17/11
If by "protected" you mean the dotted sleeves. Exchange them
Gordo 93TT Daytona
21:52:14 12/17/11
