TwinTurbo.NET: Nissan 300ZX forum - Knock sensor moved. Is it still accurate?
Subject Knock sensor moved. Is it still accurate?
Posted by OverZealous (CT) on November 14, 2011 at 7:43 PM
  This message has been viewed 1082 times.
In Reply To Octane Vs. Boost posted by Greg D. (Specialty-Z) on November 14, 2011 at 03:15 PM
Message Thanks for the nice write-up, Greg!
Whenever people have trouble with the knock sensor they often move it to a more convenient place on the plenum. I suspect the knock sensor was located deep in and on the block with good reason: that's where you get the most accurate response out of the sensor.
Are those Zs that moved their knock sensor a greater risk because the sensor is less sensitive, i.e. the stock ECU wouldn't even pick up on the wrong gas, or a tuner might overboost the engine because he couldn't recognize the onset of knock early enough? Or do you believe changing the sensor location is no big deal?
OverZealous (CT)
view My Technical posts (click here)
view My General posts (click here)
