TwinTurbo.NET: Nissan 300ZX forum - A little trick I use when installing the clutch is to find
Subject A little trick I use when installing the clutch is to find
Posted by Ash's Z on March 16, 2011 at 12:28 PM
  This message has been viewed 369 times.
In Reply To I give up! Time to sell it! posted by rojoloco (San Diego) on March 16, 2011 at 08:27 AM
Message center of the disc with the alignment tool before tightening one of the 12mm bolts for the pressure plate.
With the alignment tool in place, wiggle the clutch disc up and down, left to right, and locate dead center. While holding it center, tighten up one of the pressure plate bolts a little - enough to hold it in place.
This helps with the input shaft alignment to the pilot bushing during tranny install.
Enthusiasts soon understand each other. --W. Irving.
Are you an enthusiast?
If you are out to describe the truth, leave elegance to the
tailor.
Albert Einstein
