TwinTurbo.NET: Nissan 300ZX forum - how would power from .5 inch larger IC piping compare
Rogy
on December 10, 2010 at 5:57 PM
Im going to be upgrading to Ashspec Massives
posted by Nis300owner
on December 10, 2010 at 12:30 AM
with driving in 50F weather??? If its the same or better, then im upgrading
Nis300owner
00:30:26 12/10/10
I believe SZ can modify the stillens to 2.5 in and out maybe
5280Z_nightstalker
00:38:31 12/10/10
they can but they wont be as thick as the massives
Nis300owner
00:44:16 12/10/10
Just throwing it out their as a cheaper alternative.
5280Z_nightstalker
00:54:31 12/10/10
Waves magic wand.....
SeanK (StL)
01:29:20 12/10/10
damn (n/m)
blackomega
01:37:16 12/10/10
I knew that graph was around but I didnt notice they did
5280Z_nightstalker
01:41:21 12/10/10
I'll do you one better.
ZiNnYc
03:43:24 12/10/10
Good link. (n/m)
SimaYi
11:03:59 12/10/10
bookmarked, great info. (n/m)
fantomZ(OH)
13:55:41 12/10/10
Most helpful post from you in over a year...
ni[X]it
16:41:05 12/10/10
kma (n/m)
ZiNnYc
18:45:53 12/10/10
2nd (ni[x]it) (n/m)
CoHPhasor
19:23:39 12/10/10
there is a flaw in that thread regarding crossflow theory
aliaZ
16:54:17 12/10/10
Are the AshSPEC Sport SMICs *essentially* the same
07:42:50 12/10/10
IIRC, they were the same until Ash left Z1. Now I think Ash
PiotrC70
08:31:34 12/10/10
Same cores, both cast aluminum endtanks with what look to be
ZiNnYc
08:35:43 12/10/10
Same core, different endtanks. We cast our endtanks but
Ash's Z
11:12:53 12/10/10
I'll post a pic of mine when I get home. I got them used
11:22:09 12/10/10
You'll need to mesure the i.d. of the inlet/outlet ports
Ash's Z
12:00:23 12/10/10
I'd like to see what you could do with your 2.5" piping
not4resaleZ
21:23:57 12/10/10
i would definately consider modifying my GReddys because
blackomega
01:28:07 12/10/10
TIG welder, some practice and proper technique and ur good (n/m)
Ted(Snowflake..)
04:33:33 12/10/10
Ash can modify them for you. Link to pics of my modified
Mr.Stacy
05:06:23 12/10/10
Chart above doesn't seem accurate-Greddy's dont look so good
ZXoltan
09:00:46 12/10/10
Ash did the tests.
Woody75 (Denver)
09:32:33 12/10/10
I agree. Would be nice for someone to reproduce and validate
ZXoltan
09:39:26 12/10/10
You could always just have your ICs flowtested by someone
Ash's Z
10:33:53 12/10/10
Q
10:59:09 12/10/10
Why don't you test them all at 200 cfm and 15psi or 20psi
not4resaleZ
13:05:58 12/10/10
The power requirement to move that much air
Jim (Selin Design)
13:35:17 12/10/10
The problem with data logging is you would have to block
not4resaleZ
15:30:05 12/10/10
On a dyno pull you wouldn't have
Jim (Selin Design)
17:14:32 12/10/10
Thermodynamically speaking >>>>
Ash's Z
14:17:14 12/10/10
To put it simply, it's not necessary to do this...
LitlElvis
15:07:16 12/10/10
but your engine will only flow about 200 psf max. (n/m)
not4resaleZ
15:34:26 12/10/10
Re: but your engine will only flow about 200 psf max.
not4resaleZ
15:45:40 12/10/10
That looks to be some rendition of a formula for
LitlElvis
16:00:59 12/10/10
I'm sorry, I mean 200 cfm. This is based on the engine
not4resaleZ
16:07:22 12/10/10
Ok, at 7500RPM and 0psi a 3.0L engine moves ~199CFM
LitlElvis
16:40:28 12/10/10
clarification
aliaZ
17:21:22 12/10/10
I know, I should have used "SCFM" instead of "CFM"
LitlElvis
18:16:07 12/10/10
agreed (n/m)
aliaZ
18:21:08 12/10/10
I would describe it as, when the air filter sees 414 cfm
not4resaleZ
17:26:14 12/10/10
This is a standard formula for pressure drop in a pipe.
not4resaleZ
16:04:19 12/10/10
I like bell intercoolers charts. They test cores using a
not4resaleZ
13:21:15 12/10/10
...I dont think the Bells have aluminum endtanks like the
ZiNnYc
13:35:42 12/10/10
Greddys only flow a bit more than stock.
The Hawk
12:41:10 12/10/10
This is the opposite of anything I have ever heard. (n/m)
blackomega
13:09:44 12/10/10
2nd- although my info comes primarily from TT.net postings (n/m)
ZXoltan
13:44:34 12/10/10
As discussed above, the chart from Ash
The Hawk
19:07:59 12/10/10
Interesting since in empirial testing i found
ztunerz
20:18:54 12/10/10
Ignore the spelling errors-touchscreen sucks (n/m)
ztunerz
21:05:19 12/10/10
False. (n/m)
Only1Z
14:56:10 12/11/10
500 to 700 (n/m)
Dane (Houston)
00:44:37 12/10/10
how would power from .5 inch larger IC piping compare -
Rogy
17:57:44 12/10/10
You haven't been paying attention have you?
CoHPhasor
19:54:56 12/10/10
thk you, I just needed a basis for comparison..words instead
Rogy
22:28:47 12/10/10
Hahah! No worries my friend :-D
CoHPhasor
02:11:10 12/11/10
