TwinTurbo.NET: Nissan 300ZX forum - anyone who doesn't pull a vacuum when charging a system
aliaZ
on June 18, 2010 at 10:39 PM
2ND, Vacuum Procedure May Be the Secret..
posted by ttz'in (NorCal)
on June 18, 2010 at 10:58 AM
is a hack. Not what I would call a secret...more like common sense
Converted to R134 last week
DreamZ90
09:45:18 06/18/10
$60, what all did you do?
FuerGrissa
10:08:41 06/18/10
Re: $60, what all did you do?
DreamZ90
10:24:02 06/18/10
Sorry that should be picked up and put in (n/m)
DreamZ90
10:25:25 06/18/10
What came with the conversion kit? (n/m)
hunterg
13:45:08 06/18/10
I'm right in the middle of this step in my NA-TT conversion
hunterg
13:52:21 06/18/10
Is this the kit you used?
hunterg
13:56:20 06/18/10
pressure switch for r134, and new dryer
Agent X
14:41:31 06/18/10
I left everything (n/m)
DreamZ90
21:09:32 06/18/10
I used the Quest kit with retro fit
DreamZ90
21:15:59 06/18/10
the old oil cannot be vacuumed out
aliaZ
13:56:36 06/18/10
what is the correct method to drain old oil from compressor?
hunterg
14:07:18 06/18/10
correct method is to drain the compressor
aliaZ
14:26:25 06/18/10
Man, that is a helpful write-up. Thanks! (n/m)
The Hawk
15:37:25 06/18/10
you're welcome (n/m)
aliaZ
20:12:15 06/18/10
Can you flush it and retro fit it while in the car?
ChrisZTT(Sacto, CA)
16:27:45 06/18/10
to some extent, yes
aliaZ
20:11:41 06/18/10
Where is the AC dryer located? (n/m)
ChrisZTT(Sacto, CA)
20:34:12 06/18/10
passenger side of the condenser behind the headlight (n/m)
aliaZ
20:56:00 06/18/10
I can't see anything behind the headlight. What does the
ChrisZTT(Sacto, CA)
00:43:28 06/19/10
It's the black cylinder that sits next to the pass side horn (n/m)
Guapo
00:54:11 06/19/10
GTL This One...Thanks DreamZ90
ttz'in (NorCal)
10:35:36 06/18/10
ttz'in (NorCal)
10:58:25 06/18/10
anyone who doesn't pull a vacuum when charging a system -
aliaZ
22:39:52 06/18/10
and who said common sense was common ?
ttz'in (NorCal)
02:40:48 06/19/10
Also new receiver/dryer everytime system is opened. (n/m)
Ashman2k2
01:16:37 06/20/10
did the same thing and i love it......
Firstgearlaunch(Atlanta)
15:49:43 06/18/10
To do this do you have to change the oil in it? (n/m)
ChrisZTT(Sacto, CA)
16:29:00 06/18/10
it is best to change the oil to one that is compatible with
aliaZ
22:37:12 06/18/10
so you just refilled it without fixing your leak?
aliaZ
22:30:01 06/18/10
Yes, Very Loud Noise!!! (n/m)
BoneZ
23:08:29 06/19/10
Changed to R134a using used parts
DaZedMan
20:07:00 06/18/10
