TwinTurbo.NET: Nissan 300ZX forum - Diff. oil cooler Info
Subject Diff. oil cooler Info
Posted by toykoz32 on April 19, 2010 at 3:15 PM
  This message has been viewed 556 times.
Message This is the info Nissan sent to me today about the pump:
For any type of sustained high-speed driving a differential oil cooler should be installed to reduce the heat build-up and prolong the the life of the ring and pinion, Limited-Slip assembly, bearings and seals.
The pump has a maximum flow rate of 1.6 GPM.
Full plumbing should include a -10 line into and a -8 line out of the pump and a 75 micron filter mounted between the differential and the pump assembly.
Part # : 21660-37P00
Price will vary depend on who you get it from, I know my cost is really cheap. But the cost should be between 313.00 - 400.00
Im being told that it will come with all brackets and associated hardware as well.
