TwinTurbo.NET: Nissan 300ZX forum - Installing new throttle body bearings after powdercoating:
Subject Installing new throttle body bearings after powdercoating:
Posted by whip (Philly) on March 19, 2010 at 4:24 PM
  This message has been viewed 757 times.
Message After disassembling and having my throttle bodies powdercoated, I figured I would install new bearings for peace of mind. I lucked out and found a NSK supplier for the bearings. I will get into the correct part # at the bottom of the post. Here are a few pics of the install:
New Bearins (right) along side old (left)
First I lubed the seating surface with some silicone grease:
I installed the new bearing into the recess, and used the old bearing (pictured, new bearing is partially seated underneath old) as a shim to avoid damaging the new bearing while pressing it in using a vise. The towel is obviously there to protect the PC finish.
This is a closeup of the correct seat of the bearing, mine went in without any binding or issues.
New bearing installed. I may do a better writeup when I install the shafts and throttle body hardware.
This method worked for me, although a socket or a wood shim could be used instead of the old bearings to assist in installing the new ones.
When the shafts are installed, I expect some movement of the bearings on one side or the other. Just a heads up. Hope this helps out a few people.
Bearing Part number
NSK 6000ZZCE PS2S
O.D. 26mm
I.D. 10mm
Bore 8mm
